TH350 will not shift at WOT - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2003, 08:56 AM
Post TH350 will not shift at WOT
Hello everyone! I've been searching around on the net for info on a problem I'm having with a TH350. From the messages I've read so far on this forum, it seems that there are a few tranny vets that know their stuff. I did a search and found another topic simular to this, but it did not answere my question. Well here goes!
Vehical specs are listed below. The transmission shift fine at anything short of wide open throttle. 1-2 and 2-3 shifts are firm and quick at 1/4, 1/2, and 3/4 throttle. Any more, no shift.
I've checked and confirmed that there is a good vacuum source for the modulator and that the modulator seems to be okay (someone told me there would be tranny fluid on the vacuum side if the diaphram was bad). The TV cable is properly adjusted and does not bind. I swapped out the govenor with another "color". There is still no difference.
Any ideas? Here are the specs for the truck.
1983 Chevy C10
Goodwrench 350/Crane 268adv duration .454int/exhaust lift/Weiand Xcellerator/Holly 750CFM DP
2500-3000stall, HD rebuild kit (less than 2K miles), red band modulator (ajustable, i think), i have both a green with yellow spring and orange with yellow spring govenor. The green is in it now.
3.73 open diff
There is no shift kit installed, but I do have one sitting here if that will help. I figured that I should find out why it isn't shifting before I installed it. After I built the motor up, the truck has sat on and off over the last 2 years (I bought a Honda to drive 80 miles round trip), mainly weekend fun. The shifting problem occured after the last stint of sitting (about 2 months). Took it to the track and found out. I drive it pretty soft around town (very loud), and it shifts fine at partial throttle. Looked like a fool at the track when all it did was bounce off my rev limmiter... Thanks in advanced for any help!
Ben
[ April 13, 2003: Message edited by: quadman_20 ]
[ April 13, 2003: Message edited by: quadman_20 ]</p>
Old 04-13-2003, 10:50 AM
airworld2's Avatar
Post
Check vacume source, at intake sounds like carbon build up, or cracked hose.If thats ok disconnect kick down cable(yea I know some reply on that will follow) reconnect if thats no help.You might try hand held vacume pump with 15 inch vacume will shift soft and soon but that might tell you where you need to look farther.
[ April 13, 2003: Message edited by: airworld2 ]</p>
airworld2
Old 04-13-2003, 11:11 AM
Post
Vacuum is fine. Hoses are fine.
I checked the metal tube also. Cleaned it out with a bit of brake clean and compressed air. Nipple on intake was just replaced and looked fine.
I did hook a vacuum gage up in line with the modulator still hooked up and it acted like it was suppose to.
I will try dissconnecting the kick down cable.
Thanks
Ben
Old 04-13-2003, 04:35 PM
adtkart@aol.com
Post
I know that you said that the TV cable is adjusted correctly and not binding. As Airworld2 hinted, it sounds to me like that may be where the problem is. If it is shifting everywhere but WOT, it doesn't sound like vacuum or an internal problem. Changing the governor should have no effect on it either, as they usually will cause no shift or late shift if it is acting up.
Old 04-13-2003, 04:47 PM
roys63's Avatar
Post
sounds like the TV cable is to tight?
Old 04-14-2003, 11:20 PM
Post
Thanks for the replies. I've been busy so I havn't been able to try disconnecting the TV cable yet. From what I have gathered (well more like what people have been telling me) that is most likely the problem.. Makes sense.. The transmission is wanting to "kick down" at WOT..
Thanks again
Ben
