Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th350c lock up, does not function?
Old 05-28-2012, 03:33 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good info; '81 began ECM TCC control (unless CA possibly). Before then (like on my '80 Malibu wagon) it was analog, used a vacuum switch mounted on the fenderwell or firewall.
My engine doesn't use an EGR valve so I run manifold vacuum directly to the TCC vacuum switch and to the distributor vacuum advance, w/o the intake water crossover-mounted temperature switch. Using a temp switch wouldn't hurt, it would only prevent TCC lock up (as well as vacuum advance if that was also hooked through the switch) until the engine was up to temp.
