Th350C Modulator hook up - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2007, 08:46 PM
Is it alright to run all vacuum rubber hose from Modulator to Carb? I see pictures of trannys that run a short hose on each end of a steel line. Is this mandatory for some reason?
Old 10-24-2007, 09:05 PM
Will I ever get it done?
Last journal entry: Hood
The steel is more robust. Won't collapse. Harder to cut, burn, kink, or melt.
Old 10-24-2007, 09:28 PM
The hard line is way less prone to develop leaks. A leak in the vacuum source creates BIG problems for a Turbo 350 ( or any transmission with a vacuum modulator )
It also looks a good bit more professional and less " rigged "
Old 10-30-2007, 06:31 PM
70 ElCam's Avatar
Rebel with a Chevy
All of the above, plus the fact that the factory hard line is designed to prevent fluid from being gulped through the intake in the event of a modulator diaphram failure. The hard line is raised at the point of entry similar to a reverse pea trap in your lavatory j pipes. We had a SB block Camaro that would blow a huge puff of smoke out the exhaust at highway speeds every two miles or so. I finally checked the modulator and there was the problem , busted diaphram. Use the hard line if you can find one . Buy one for a mid eighties 1/2 ton pick-up with a TH350 .
Old 10-30-2007, 07:19 PM
Thanks much. I also want to know if it is OK to attach at the rear of carb. I see some attach into the manifold? any difference.? I will get some brake line and custom bend it for my application. 1974 454 Big block/Th 350 in a 1956 GMC Carryall. Keep the info coming.
Old 10-30-2007, 07:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the modulator needs direct manifold vacuum hook up
Old 10-30-2007, 07:43 PM
So that big honkin vacuum port at the rear base of the carb where I have a tee, one side to brake Diaphragm and other to tranny Modulator is no good? Should I find a threaded port on one of the intake channels?
Old 10-30-2007, 08:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that is correct, it is best to not tee off or share vacuum with another item for the trans modulator.
Old 10-30-2007, 09:23 PM
70 ElCam's Avatar
Rebel with a Chevy
Manifold
Yes, it needs to be hooked directly to the intake manifold. Some factory set-ups actually have restrictions in the line to "meter" the vacuum signal . I use straight full-time manifold vacuum through a small nipple around 1/8 " I.D.
Manual wiring toggle swith for TH350C inkrat Transmission - Rearend 23 04-07-2012 07:07 PM
TH350C shift problems tsume Transmission - Rearend 2 03-23-2007 01:40 AM
ok, th350 converter on a th350c fast68 Transmission - Rearend 1 03-17-2007 10:50 PM
TH350C Questions baspinall Transmission - Rearend 3 09-01-2006 09:56 PM
How to convert T-350C to a T-350 65 streeter Transmission - Rearend 10 01-02-2006 09:03 AM
