th350c question again. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2009, 01:49 PM
fast68's Avatar
likes chevy trucks & boobies
ok well some of you may remember that i have a th350c i pulled from an 81 chevy pickup i junked years ago that was powered by a 350 olds diesel.
i saved it over the years in case i ever needed it for anything.
i got rid of the diesel torque converter thinking i could easily locate a cheap gasoline version one
in which i have been proven very wrong
its a perfectly good trans id like to make available for use instead of taking up space here as usual.,
can i simply hack off the o ring center input shaft and use a non-C converter?
just to run the trans?
thanks
Old 07-27-2009, 03:20 PM
tnsmith10's Avatar
when will it rain???
thanks
no,the stator must be changed, and the t.c.c. valve needs to be blocked, and a hole drilled in the small plate next to the tcc body.
as far as a converter goes, whatever it takes trans parts has 1, heres the link:https://www.wittrans.com/QuestionPar...?Question=1641
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
How to convert T-350C to a T-350 65 streeter Transmission - Rearend 10 01-02-2006 09:03 AM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
