TH350C Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2006, 07:23 PM
TH350C Questions
OK here is my situation. Please be patient I have a rather long mess of ???'s. I have a Nomad with a 283 and a spent TH350. I just got ahold of a TH350C. I'd like to rebuild it myself (never did this before but want to learn). Will this tranny be an OK set up with my 283? Should I leave the lockup connections un-wired or wire them and use the features of a TH350C? If I do wire this up, where do the two wires go? I think one is wired to 12V constant. Don't know about the other. I have also heard that I should add a vacuum switch to turn off the lockup?
One more, are these any harder to rebuild than a standard TH350?
Thanks for any help.
Old 09-01-2006, 10:08 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
not much difference to build the 350c.
i would verify it is a t350c.
check for a threaded stud with nut near the cooler lines. It sticks out from the case in that area..... IF there is a stud it is a 250c.
NO stud indicates a t-350c.
have fun.
Old 09-01-2006, 11:10 AM
Its a TH250
Is a TH250 worth rebuilding to put behind a 283?
Thanks Brian
Old 09-01-2006, 10:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I scrap them out , save a few parts from them.
Thanks Brian
Two questions about a BBC RObs71Nova Engine 10 07-03-2012 03:55 PM
How to convert T-350C to a T-350 65 streeter Transmission - Rearend 10 01-02-2006 10:03 AM
Interior -- Common Questions Jon Interior 0 02-12-2004 05:38 PM
Suspension-Brakes-Steering Common Questions Jon Suspension - Brakes - Steering 0 10-16-2003 04:19 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 03:01 PM
