th350c valve retainer help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2009, 03:43 PM
fast68's Avatar
likes chevy trucks & boobies
towards the back of a th350 case on the passenger side theres a long skinny valve that runs parallel to the trans.
there must be a cap or something that retains it on the exterior of the case casting
there is an o ring
it is around 3/4" diameter
mine came out of my th350c trans as i was flipping it over to pull the pan
i cant find a cap or retainer or anything
no spring either
i put the valve back in the hole and it slides in all the way and bottoms out
what am i missing
i been saving this good tranny for all these years until i could ever some how find a gas engine torque converter for it, because this one was in an 81 chevy 2wd pickup with diesel olds 350 from factory.
and now this ****ing happens
dammit..
help ?
thanks
Old 07-23-2009, 04:37 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
You can relax.
The modulator goes in the hole. A bracket holds it in place. It bolts in that threaded hole just above it.
Old 07-23-2009, 05:54 PM
fast68's Avatar
ah crap i forgot all about the modulator i must have robbed it for another trans
i swear the modulator is on the trans but maybe not, damn lol
i need to look again
thats a real brain fart haha wow..
hmm
i freaked out when i saw a valve and o ring on the ground and a hole in the case that it came from.
so im not missing anything right?
only the valve and mod valve go in the hole and no spring or anything else?
how does that mod valve pull or push this valve in this hole if it simply goes all the way in and bottoms out without any resistance or anything ?
seems really odd to me
thanks
Old 07-24-2009, 04:30 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Line pressure keeps it in place. As the vacuum pulls it open the pressure pushes it back.
There's also governor pressure and detent, so its all pretty much a mystery to me still , but all these things keep it in place w/o a spring.
Old 07-24-2009, 05:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
HERE is an exploded diagram of the TH350- click on exploded diagrams:
rear part
, from the left hand side bar.
No springs, just the valve assembly and modulator.
Old 07-24-2009, 04:00 PM
fast68's Avatar
ok good deal thanks much
line pressure hmm ok interesting
Correct way to set valves on sbc w/ solid flat tappit camshaft? Joshua Lee Engine 17 02-09-2011 05:55 PM
TH400 1-2 Valve Removal Fasterstill Transmission - Rearend 7 09-12-2008 01:24 PM
Valve trouble cdiedrick Engine 9 10-10-2007 08:05 PM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
oil being sucked threw the pcv valve on my 350 sb.. Robbie Engine 23 05-08-2004 09:12 AM
