th400 & 12 bolt driveshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2005, 02:19 PM
th400 & 12 bolt driveshaft ?
does anyone have chevelle or impala driveshaft that i could buy cant seem to find any locally cause if im not mistaken the u joints are bigger than a th350 and a 10 bolt which were in my 84 elcamino originaly
Old 10-12-2005, 03:10 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
try this
www.car-part.com they have lots of those..If you have the yoke and shaft that fits the tranny and the yoke and shaft that fits the rear you can take the mess over to the drive shaft guy and he can put the 2 together and fixx the mess..happens a lot when changing out trannies and rears from what was in the car originally..
OMT
Old 10-13-2005, 11:51 PM
400 turbo and joints
Do you have the 400 yoke? its thicker but you can find u-joints with large ends and small ends on opposite side so you can put the 400 yoke on your shaft . We should keep the part number s of because everyone has had this kind of problem . Try a couple auto parts place til someone helps size them up.
Old 10-14-2005, 08:18 AM
problem is the yoke i have is a bolt on not a slip in and it has straps for the retention of the ujoint and i want to use the bigger joints
Old 10-15-2005, 01:14 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Is that a truck transmission with a bolt on yoke?
You must have a slip yoke somewhere. You must have some length-slip on that driveshaft so the rear can go up and down.
You can't mess around buying, shipping, and altering the length of one too for the time and money it takes. Just custom build a new one.
You can get a complete new driveshaft custom made for $ 150-200.
Old 10-15-2005, 01:29 PM
ya realizr that it has too slip in thats why i need the yoke and driveshaft a chevelle shaft will be long enough that i can have it shortened having the whole shaft made isnt a option when u pay out half your check too child support
Old 10-15-2005, 08:55 PM
xntrik's Avatar
Can you put a slip yoke into the back of that transmission?
Old 10-16-2005, 05:59 AM
ya thats why im lookin for the shaft from a chevelle or impala
Old 10-16-2005, 03:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
yes, use a short slip yoke.
it is best to pull the tail housing off and check clearances with the slip yoke.
there is a groove for the sealing O ring to sit in for the bolt on yoke. This groove can interfer with a slip yoke if a long slip yoke is used
Old 10-16-2005, 03:33 PM
ya i realize that but does anyone have one thanks
Old 10-16-2005, 04:10 PM
xntrik's Avatar
I didn't realize that you can take off a bolt on yoke and install a slip yoke over that same shaft... thanks.
Stock 12 bolt housing hp/torque rating 84Z Transmission - Rearend 1 02-01-2005 07:25 PM
12 bolt rear end question Roy_67_SS350 Transmission - Rearend 3 01-04-2004 06:12 AM
3rd Gen 12 bolt Camaro2Fast4u Transmission - Rearend 0 07-06-2003 11:15 PM
10 bolt to a 12 bolt the ernster Transmission - Rearend 1 02-25-2003 08:22 PM
10 bolt or 12 bolt neil madsen Transmission - Rearend 2 02-25-2003 06:55 PM
