th400 4x4 case
does th400 come in a 4wh drive case if so what # transfer case bolts up?
To the best of my knowledge the case is the same just the out put shaft is different. Many transfer cases fit, my son has a NP208 on his.
there are 3 different shafts for 4x4 t-case applications. 203 t-case 208 & late 205 t-case early 205 t-case is a 2WD output shaft Adapters and t-case must match the out put shaft length.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Here's some info on the 205 heavy duty T-cases:
The 3&4-speed standards & TH 350 are the same T-case casting and input shaft. But each has a different stock GM adapter to bolt it up. All of those 205's have a male spline on the input shaft. The 205 T-case is different for the TH-400. That's because the output shaft for the 400 trans fits into a female spline on the input shaft of the "TH-400 only" 205 T-case. They had to make that 205 input shaft bigger which requires a bigger O.D. input bearing & hole on the T-case. The GM adapter is unique to this TH-400/205 setup. It came out in 1980, and maybe only one year?...because they started using 208's?? after that? |
Also, I did do a swap back in 1982, making a 2wd 1979 GMC with a TH-400 into a 4x4 with a 205 box.
That 79 GMC 400 2wd trans did not need a different output shaft for the trans. I did order a new output shaft for a 400 (to 205) but after looking at them, there was just a few minor things different like snap-ring grooves & lack of a threaded hole for the 2wd output yoke. (all of which were not needed) So, I sent the new shaft back. That entire driveline is still here & working fine....but now in a 66 Chevy K-20. I also converted a 4-speed 205 T-case by stripping it bare, then sent it out to machine the input bearing hole bigger to fit the new TH-400/205 input shaft & bearing that I bought from GM. I also had to order the correct adapter from GM. All the other parts inside the 205 were the same. Those parts probably are not available anymore from GM. |
| Specific TH400 identification | 93Cobra | Transmission - Rearend | 0 | 10-29-2007 05:17 PM |
| T-400 Rebuild or swap for T-350 | Silver00V6 | Transmission - Rearend | 5 | 09-23-2007 05:39 PM |
| Putting a 1987 700R4 in my 1982 GMC 4x4... | indy_85stariones | Transmission - Rearend | 12 | 04-28-2007 02:04 PM |
| Small frame (case) GM alternator donor cars | ken47 | Electrical | 3 | 05-01-2006 10:01 PM |
| TH400 Swap - 69 Camaro, currently TH350 | paulsubs | Transmission - Rearend | 3 | 10-30-2004 12:16 AM |
