TH400 in a '52 Chevy-needs trans mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2007, 09:57 AM
It's time to pull the transmission on my Chevy and I want to put in a bolt-in transmission mount. The previous owner welded in a mount from some donor car. I remembered seeing an article a couple of years ago in R&C (I think) but cannot find the article that listed who made the engine/trans mounts for these early Chevys.
Does anyone know of a company who makes a TH400 into a '52 Chevy bolt-in transmission mount?
Thanks for your help.
29guy
Old 01-01-2007, 11:36 AM
You should be able to easily modify a stock GM crossmember froma Camaro or Nova or other midsize car to use in yours. Might even be as simple as adding a couple brackets to the frame and bolting the stock member in place.
Old 01-01-2007, 11:53 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Try TCI...Total Cost Involved.....they make crossmembers and mounts for a lot vehicles.
Old 01-01-2007, 06:12 PM
Thanks Pasadena/Henry for the replys.
29guy
Old 01-10-2007, 09:22 PM
techinspector1's Avatar
Wiki Edits: 326
When I do swaps like this, I use the outer thirds of the original mount so that I have two stubs bolted to the car, then just fill in the middle third with a piece of the middle of a crossmember that will fit the transmission. Weld the 3 pieces together and you have a low-buck mount that unbolts like stock.
Old 01-10-2007, 11:15 PM
great crossmember
Walton Fabrication makes a great crossmember and a trick booster/brake/pedal combo. They have a web site so I would google them.
Old 01-11-2007, 06:37 AM
Thanks techinspector1 and 52 chopped rat,
I appreciate your help.
29guy
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
454 chevy in 79 trans am, possible? Trans Am Benny Engine 9 12-31-2011 11:06 AM
Manie's 52 Chevy manie silva Introduce Yourself 1 03-05-2006 07:02 AM
Chevy Trans. Question whynot Transmission - Rearend 5 02-21-2006 06:57 PM
Lokar trans mount E-brake 302 Z28 Suspension - Brakes - Steering 2 01-01-2004 03:31 PM
