Th400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2006, 08:32 PM
smurfy346's Avatar
Th400
Can some one tell me which is the outlet line on a TH400 Trans?
Mike
Old 01-30-2006, 09:03 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
IMHO, on just about ANY automatic the pressure line is the one closest to the pump (in the front).
Old 01-30-2006, 09:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
That statement does not function with all trannys.
Since both cooler lines on a t-400 are at the front area of the case , one located over the other. Which is the line out per your thoughts?
the bottom fitting is the "line out" from the t-400 tranny
Old 01-31-2006, 07:23 PM
smurfy346's Avatar
Thanks Crosley, I thought the bottom was the outlet. Thanks again.
Mike
Rebuilding a TH400 switch pitch Wmarden Transmission - Rearend 2 09-16-2004 12:54 AM
TH400 Trans bfrett123 Transmission - Rearend 1 09-10-2004 07:16 PM
TH400 only has reverse Wmarden Transmission - Rearend 3 09-10-2004 11:49 AM
TH400 power handling and RPM range Philly Single Transmission - Rearend 3 09-28-2003 05:51 PM
TH400 in firebird v/s TH400 in bonniville help speedfrk3 Transmission - Rearend 11 11-04-2002 12:19 PM
