th400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2002, 09:46 AM
Post th400
I have a GM 400 in my 48 chiv sedan delivery behind a build 350, my question, is there a way to lock the trans in 1st gear? When I put it into 1st gear and go it automatically shifts to 2nd gear. The linkage seems ok. any thoughts
Thanks oldnable
Old 05-02-2002, 04:42 PM
Post
Im not sure about 400 or if there basically the same as a 350 but I replaced the spring and blocked the movement on the manual low control valve,in the valve body with small round disc.shims this acheived manual or automatic operation.(Roy newton exprotech the trans.man maybe give him a holler )
[ May 02, 2002: Message edited by: wrenchturner ]
[ May 02, 2002: Message edited by: wrenchturner ]</p>
Old 05-02-2002, 07:00 PM
Post
I'm not an auto trans expert, but my experiences tell me to recheck the shift linkage adjustment. I've never had a problem keepin any auto in 1st when shifted to that position. I'm thinkin maybe verify the adjmt at both extremes on the selector.
