th400 adapter help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2006, 10:58 AM
th400 adapter help
So i just finished dropping my 383 chevy in my 1980 transam that has a bop th400. I bought an adapter on ebay to fit the chevy motor to a bop trans. I bolted up the transmission to the engine and now there is about a 1/2 inch in between the torque converter and the flexplate. on jegs, i read that there kit comes with the plate, bolts, and spacers. has anyone used those spacers before? if so do you know how big they are? I have a bad feeling the spacers may go infront of the flexplate, i was just going to put them in between tc and fp. Any help or suggestions is greatly appreciated, i just want to get this car on the road before summer has passed me by. thanks!
Old 06-10-2006, 11:04 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
You can prbably use just flat washers between the flex plate and the converter. What you will have to be careful of is that the hub on the converter still engages the end of the crank. 1/2" is a lot to space back.
Old 06-10-2006, 11:10 AM
Thats what i was planning on doing but like you said, thats alot of space and i thought id check to see if anyone else has used one before. thank you.
Old 06-12-2006, 05:18 AM
i put a caddy engine in my GMC, used a chevy TH400 with an adpater plate. I ended up cracking 3 flexplates before I figured out the problem and went with a BOP trans....good luck
AN-6 adapter for fuel pipe? pcoghlan Engine 8 03-18-2006 06:44 PM
SBC Oil Cooler Adapter Delirious2000 Engine 1 02-19-2006 10:21 PM
TH400 only has reverse Wmarden Transmission - Rearend 3 09-10-2004 10:49 AM
TH400 power handling and RPM range Philly Single Transmission - Rearend 3 09-28-2003 04:51 PM
TH400 in firebird v/s TH400 in bonniville help speedfrk3 Transmission - Rearend 11 11-04-2002 11:19 AM
