Hotrodders Bulletin Board
#1
Th400 Broke on Double points race.. :o(
I purchased a Th400 and a 4500 stall converter at the begining of last season, only to have it come apart yesterday during a double points race...
I had maybe 50 passes on it behind a 400-450hp SBC... it should have lasted forever... attached is a picture of what I found in the pan... I'm not a transmission person, but from what I've found out they are the parts of the case that were suppose to retain a snap ring that holds the clutch pack in place... tell me what you think would have caused this to happen... thanks |
#2
re: Th400 Broke on Double points race.. :o(
I little more info...
I made 3 qualifing passes and went four rounds in eliminations the day before... only thing out of the ordinary was that on the last pass my trans temp went higher than normal... over 200... but trans seemed to still work. drove back to pits and sat until the next day... next day seemed fine pulling up to make first pass for time trials... burn out was off, thought my posi was slipping again... pulled up and took the green... lauched seemed ok but shifting to second sent the tach sailing... |
#4
planning on pulling it tomorrow... called the company/guy that built it for me today, but he has yet to get back to me... suppose to have a year warranty so hopefully he will stand behind it... otherwise I will have it looked at locally... I'm hoping that the damage is limited to the case... and it can be put back together without alot of $$$...
why would this part of the case fail?? My little ole 355 should not have been able to caused this damage... could it have been a bad case?? trying to have some background before he calls me.... Last edited by nastynova : 05-27-2008 at 08:48 PM. |
#5
Common failure in a t-400 case since GM introduced them.
hopefully your builder had a wide snap ring in it. I suggest use of the waved cushion steel plate in all t-400 intermediate clutch pack setups.
======== If you can't fix it with a hammer, you have an electrical problem. |
#6
400 broke
Crosley suggest the waved steel plate because the trans needs the absorption[usually high line pressure on racing trans]. Not a bad idea in the direct drum, as well.
The most torque this trans will see may be during the 1-2 upshift. A wide snap ring from a 727,chrysler trans, [forward clutch drum], will, most times, mitagate the severe stress that is exerted on the case during the 1-2 upshift. I doubt this was done and the result will be a ruined case. |
Back to top |
Similar Threads for: "Th400 Broke on Double points race.. :o("
| setting points on sb chevy | frackster66 | Electrical | 14 | 03-22-2008 10:33 AM |
| Stealth marketing bust: Race Ready Performance | Jon | Hotrodders' Lounge | 0 | 03-20-2008 01:05 PM |
| th400 shift points?? | rolrandy | Transmission - Rearend | 1 | 02-20-2008 07:18 AM |
| Changing the points question | ggassert | Engine | 2 | 07-30-2007 10:23 AM |
| TH350 vs TH400 vs Glide | GearHead69 | Transmission - Rearend | 3 | 10-02-2003 11:30 AM |
