Th400 casing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2005, 11:13 AM
1300
Th400 casing
Quick question: what casing and bellhousing have Turbohydramatic400?
Old 07-11-2005, 12:46 AM
jalopy45's Avatar
Not really sure what you want but, the th400 was available in the BOP(Buick/Olds/Pontiac) bellhousing and Chev bellhousing and you can find some with an American Motors bellhousing out of Jeep Wagoneers.Depending on their application they could have a short output shaft , a long one or an adapter to a transfer case.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 07-11-2005, 11:18 AM
BOBCRMAN@aol.com's Avatar
You may also find one with the old Buick "Nailhead" pattern. Round like the AMC, but only for 401-425 Buick.
Old 07-11-2005, 03:48 PM
Jags too............Yes, I said Jaguar........
The long and short tail housings also have 2 or more seal sizes....don't ask how I found that out.......
What's needed for a th350 to a th400 swap? Fil Transmission - Rearend 2 09-16-2004 03:09 PM
Rebuilding a TH400 switch pitch Wmarden Transmission - Rearend 2 09-16-2004 12:54 AM
TH400 power handling and RPM range Philly Single Transmission - Rearend 3 09-28-2003 05:51 PM
67 firebird th400 info speedfrk3 Transmission - Rearend 2 12-10-2002 06:31 PM
TH400 in firebird v/s TH400 in bonniville help speedfrk3 Transmission - Rearend 11 11-04-2002 12:19 PM
