Th400 clutch packs - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2006, 12:13 AM
68novafan's Avatar
Ford Fan At Heart
Th400 clutch packs
Rebuilding a th400 in a friends garage, well the clutch packs that i removed in order and stacked for reference got tossed about and now i cant figure out how to repack the direct clutch packs and what not. diagrams or info would be a huge help, I dont think there where any waive plates but the rebuild kit has waive plates in it just to confuse me more, it had the apply ring then i think just a pressure plate, but again if anyone could help me id apreaciate it. the old plates all look like waive plates just in case your woundering why i cant tell, it was a mess in there thanks!
Old 10-02-2006, 05:06 PM
jakeshoe's Avatar
http://www.nastyz28.com/forum/showthread.php?t=58578
That may help you some.
You need to get an ATSG tech manual, it will help you immensely. Ron Sessions "How to Rebuild and Modify the Turbo-Hydramatic 400" would also be good.
On the direct stackup, you do not have to use any cushion plates. If it is a race only application, just use the flat plates, once the apply piston is installed in the drum you would put a steel plate, then friction, then steel, etc, until you have 5 of each (most stock applications), then the pressure plate and snap ring.
If it is a moderate street application or near stock, use a cushion plate on the apply piston first, then you can use the flat steels for the rest, or for a "comfort" application use 2 cushion plates in the directs, it will reduce the reverse apply harshness.
Busted Clutch chrisflock Transmission - Rearend 1 04-15-2006 04:08 PM
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 04:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 10:26 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 08:04 PM
Th-350 and TH-700R4 clutch packs. Silver_Camaro Transmission - Rearend 1 12-28-2003 09:24 AM
