TH400 down shift cable? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2003, 10:42 PM
akm akm is offline
i have a TH400 with the electronic type down shift, instead of a cable.
i was wondering if there is any way to install a cable type in its place? i'm putting it in a 65 chevy SWB pu, and this type needs some sort of switch that i don't have and have no idea where or how to make it work on my truck.
thanks
Old 08-21-2003, 11:34 PM
I believe that all turbo 400's used the soliniod kick down I've never seen or heard of one with a cable type kick down
Old 08-21-2003, 11:56 PM
Coleman396's Avatar
That switch is a simple on and off switch such as a brake light switch on a car or motorcycle. The brake light switch on a motorcycle works really well as they are so compact. Lokar makes a real beauty but it does not come cheap.
Old 08-22-2003, 12:02 AM
akm akm is offline
how would i make that work, on the carb linkage or the pedel?
Old 08-22-2003, 05:01 AM
Lokar makes a really nice switch that bolts to the pan bolts and has a stainless steel cable running up to the carb to operate it.
Old 08-22-2003, 07:34 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
I've used a stop light switch off a motorcycle at the carb.
you have to build the carb mount, use a spring and small piece of chain to connect it.
add some wires and it works well.
Old 08-23-2003, 10:58 AM
GM used the switches on the intake or under the dash, depending on application.
