We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 08-05-2006, 09:53 PM
Twistedwrench's Avatar
Twistedwrench Twistedwrench is offline
No officer I won’t do it again
Th400 electronic speedometer / speed sensor Chevy truck
If you know the answer to this please help? I have an 82-flatbed car hauler that the cab was shot on. I converted it to a 93 cab and tbi engine. The donor truck that the cab and engine came from was a 93 k1500 with a 5.7 and automatic transmission. everything on the swap went perfectly until I went to hook up the speedometer cable. Surprise, there is no speedometer cable on the 93. It used a pulse generator or speed sensor that screwed into the transfer case. Does anyone know of a Chevy that used an electric speedometer that I can put into my th400 to operate the speedometer? I am not sure but I think it also needs that signal to run the fuel injection correctly? I swear I have seen them before in an s10 or something? This may not be possable but I thought its worth a try and see if anyone has an idea and can help. I know this isn’t a hot rod, but it does haul them, lol greatly appreciate any ideas. Thank you
Old 08-05-2006, 10:01 PM
Chazmac Chazmac is offline
GM did use gear driven electronic speed sensors; late 80's to early 90's ('88-'92?) that will fit the T400 case.
Did you check the knowledge base?....
Old 08-05-2006, 10:43 PM
Actually I have been through the knowledge base and I use its helpful information for many things. Maybe I should edit and ask more specifically as to what vehicles they were used in?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Th400 electronic speedometer / speed sensor Chevy truck"
new world truck speed record hoodoo Hotrodders' Lounge 4 01-10-2007 12:43 AM
little eddy-1950 chev truck lowbux Introduce Yourself 5 03-05-2006 11:47 AM
59 Chevy truck Speedometer garretthes Interior 3 11-12-2004 09:39 PM
700R4, cruise & electronic speedo 302 Z28 Transmission - Rearend 10 10-31-2003 12:28 PM
Ebay Truck Headache CrashFarmer2 Hotrodders' Lounge 8 09-06-2003 07:30 PM
