Don't open that pump unless you know how to put it back together properly which isn't hard to do at all but you need to have everything match up properly and know what it is you're looking at so I don't recommend opening it up either. Get a flathead and try to tap up the lip of the seal a little bit from the pump with a hammer, then you should be able to pry it out. Why someone would put loctite on a seal amazes me..
