Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th400 front pump seal question
Old 06-30-2006, 01:12 AM
meev182 meev182 is offline
Originally Posted by Jmark
I wouldn't open the pump. Usually, you can get under the edge of the metal seal from the outside edge and pry it up a little. If it still won't come out, I grab that bent edge with some vice grips and lever it out.
ok, thank you. i will go out tomorrow and try some more.
