TH400 kickdown - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2006, 11:57 AM
TH400 kickdown
I am thinking about making my own kickdown for the th400 in my pickup. Where would be the best place (engine or in cab under accelerator) for the switch? Also, do you want the switch activated at wot or earlier? Thanks in advance.
barry
Old 06-05-2006, 12:33 PM
What year truck?
See my photo album. I mounted a stock switch on the back stud of the carb and inserted an adjustable trigger plate in the carb linkage. Works great.
Old 06-05-2006, 12:53 PM
Thanks for the reply. I'm using a 350 sbc out of a 78 chevy p/u. The throttle is a cable as opposed to your threaded setup. I was thinking of just making a bracket and mounting a micro switch on it with a long actuator arm. Would setting it so it would kick down at say 3/4 throttle be about right?
Barry
Old 06-05-2006, 01:15 PM
I would use the factory switch because it has a long throw after the switch has been activated. So, it doesn't stop the throttle after it has been depressed. They don't cost much and any chevy dealer will have it in stock.
Yes, I have mine kicking in at about 3/4 throttle and it works nicely.
If you are running a Q-jet, you may be able to find a stock th400 kick down setup at your local U-Pull-It type auto salvage yard. Otherwise, I'm sure you could come up with something similar with a little fabrication and some shade tree engineering.
Old 06-05-2006, 01:52 PM
It is easy to make a neat little switch ... that's what I did ...
ID:	12613   Click image for larger version
Ford C-4 Kickdown Question Z-Money Pit Transmission - Rearend 2 10-11-2005 02:34 PM
TH400 kickdown voltage? 6426yy Transmission - Rearend 1 03-24-2005 08:10 AM
TH400 kickdown zeker6 Transmission - Rearend 1 10-25-2004 04:39 AM
TH400 Kickdown trouble midget66 Transmission - Rearend 0 12-03-2003 12:21 AM
TH400 in firebird v/s TH400 in bonniville help speedfrk3 Transmission - Rearend 11 11-04-2002 11:19 AM
