Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 03-27-2008, 10:02 AM
29guy 29guy is offline
TH400 leaking
Here's the deal, After sitting for a year (outside and unheated) my trans is leaking from the pan as well as the speedo connection. When parked I do not believe it was over-full nor did it leak.
I am getting ready to put all new gaskets on it, but wonder if there could be other issues that result from sitting too long? Is there such a thing as the valve body sticking in a position that allows ATF within the transmission to drain back into the pan? Suggestions are greatly appreciated.
Thanks,
29guy
Old 03-27-2008, 10:19 AM
pontiacjosh's Avatar
pontiacjosh pontiacjosh is offline
84 stroked ss
re: TH400 leaking
you may want to check on top of the tranny it should have a vent maybe the vent could be plugged up
Old 03-27-2008, 02:26 PM
briscoe briscoe is offline
400 leaking
Upon start up, the converter is "charged" with fluid, from the sump to the pump, then to the pressure regulator valve.
The converter fills and to a certain degree, stays charged with fluid after you shut the engine off, for awhile.
Normal wear on bushings, splines, leaks because of thermal cycles,[metal not flat anymore] and a host of other things, will cause the torque converter to drain back into the sump[pan] after some time.
Also, especially in your case[sitting for a year] seals and gaskets will be impacted by non use.
If everything was fine when you parked it, then everything should be ok now, with the exception of your various small leaks.
Old 03-27-2008, 06:21 PM
Thanks
Pontiacjosh and briscoe,
Thanks for the replies, I am going to replace the gaskets, check the vent and see how it does.
Regards,
29guy
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "TH400 leaking"
th400 Rebuild or swap for th350 Silver00V6 Transmission - Rearend 5 09-23-2007 05:39 PM
Leaking TH400 TheMonkey Transmission - Rearend 4 11-11-2006 06:20 PM
leaking th400 zephyrc Transmission - Rearend 3 05-21-2006 10:22 AM
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 06:26 AM
th400 leaking fluid v8s10 Transmission - Rearend 4 03-16-2003 12:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
