th400 making strange noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2006, 01:04 AM
markzepp820's Avatar
hello, I have a 79' chevy truck with a th400. Just recently, my tranny is making this abnormal hum-whine sound. It makes this noise at low speeds(20mph and under). When I start to take off, the noise gets more of a higher pitch the faster I go. Then from 20mph or so slowing down to a stop, the pitch of the noise gets lower. Idling at a stop, it is quiet. Does anyone know what this might be? Thanks in advance,
Mark
Also, I know my water pumps a little noisey from time to time, but it seems to be coming from the tranny...its hard to tell when driving.
Old 09-10-2006, 11:53 AM
jakeshoe's Avatar
Pressure regulator buzzing, probably sucking air, check fluid level, change filter, be sure there are two o-rings on the top of the pickup tube where it goes into the case, replace the filter it could be clogged.
Old 09-10-2006, 12:43 PM
runn141's Avatar
years ago before i knew about cars my dad had a 400 turbo that done the same thing. he had to have it rebuilt, i still dont know what it was im guessing the front pump but i dont know . id like to know what it is when you find out.
Old 09-11-2006, 11:18 PM
sbchevfreak's Avatar
Licenced Automotive Technician
I would guess it's a geartrain noise. When @20 mph or less, you are in 1st gear speed reduction so you will be hearing the planetary pinions running around the sun gear. When the upshift to 2nd occurs, the planet pinions stop rotating, and thus are silent. If it bothers you, rebuild it w/new parts. If not, I've seen ones that have run like that for many years w/o problems.
Old 09-11-2006, 11:45 PM
re: th400 making strange noise
sounds good, thankyou
strange trans noise Dainleljedal06 Transmission - Rearend 2 04-30-2006 08:51 PM
Strange rumbling/buzzing noise from 1983 5th Ave 1983lux Engine 1 01-20-2006 12:55 PM
t-5 making strange noise after having it apart....... Gino Fultano Transmission - Rearend 0 09-14-2004 09:48 AM
strange whining noise from T-400 .. Fizz Transmission - Rearend 17 07-04-2004 12:58 PM
Strange noise Camaro2Fast4u Engine 2 06-12-2003 03:05 PM
