TH400 with no speedo capabilities - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2008, 08:38 PM
Slomotion34's Avatar
Last journal entry: Mini Tubbing a 1967 Firebird Convertible Part 1
I have a Mikes TH400 in my car and I just noticed that there is absolutely no provisions for a speedometer hookup (there is actually a freeze plug in the hole where the cable would normally go). I guess not to many people that run reverse valve body trans brake 1000hp rated trannies need to know how fast they are going....
Does any know if there are any alternative speedo pickup/sensors available for this type of situation or am I just going to have to learn to say "sorry officer, but I really have no idea how fast I was going"? Guesstimating by tach is an idea.... but if anyone knows of a better idea, I'm listening.
Old 04-22-2008, 09:51 PM
Was this trans originally out of a mid-60s Olds full size? Those cars actually drove the speedo cable off one of the front wheels and the trans typically came with the normal speedo hole blocked off. The other alternative is that this is a truck 4x4 trans case.
Either way, you can easily knock out the freeze plug and a TH400 speedo driven gear adapter should be able to bolt right in. The question is, does your trans have the speedo drive gear on the output shaft? If it is, problem solved. If you, you'll need to pull the tailhousing to press a new drive gear on the output shaft. Again, either way, this should not be a big deal unless you have some sort of weird oversize output shaft.
The Following User Says Thank You to joe_padavano For This Useful Post:
bones455 (04-15-2016)
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
punch the plug out... should be able to fit a speed-O in.
TH400 Speedo size Derkyb Transmission - Rearend 0 08-21-2007 07:27 PM
SW speedo question 37fordpickup Electrical 2 12-19-2006 10:14 AM
Speedo cable interchange TH350 to TH400 Derkyb Transmission - Rearend 2 09-16-2006 05:58 PM
Speedo calibration novatech Transmission - Rearend 2 02-12-2004 08:46 PM
Speedo not working..4spd Trav Transmission - Rearend 5 07-31-2003 02:21 AM
