TH400 shift point...help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2002, 10:32 AM
Post TH400 shift point...help
I need to change (if I can) the speed at which my 400 upshifs. between 20 to 30 mph, it starts to whine and strain to shift up. It does so at 30-35 mph, but at that speed I'm over the speed limit (light to light). So here I am cruising at 25 mph, and my tranny sounds like I have a demon in it screaming to get out. It's embaresing, but am I also hurting the tranny?
This is pretty much an unknown TH400. I'm fairly sure it has a shift kit. :o :o <img src="confused.gif" border="0">
Old 10-14-2002, 11:18 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Get an adjustable vacuum modulator (any trans aftermarket supplier) With it, you can set your shift points with an allen wrench.
