Yep. Sounds like a vac modulator to me.
well first ensure that you are getting engine vacuum to the vacuum modulor. The vacuum line will run from the intake down to the passager side of the transmission. Get Under the car and find your vacuum mondulor it will be on the passager side with a rubber or metal line(with a rubber tip) attached to it.
Pull that line off and use your figure to test for vacuum or use a vacuum gage to test it. If there is vacuum in the line then your diaphram in the vacuum mondular may have failed. To remove the modular you will find a bolt beside it that holds a tank against it. Once you remove this bolt it will just pull out. |
If you have to replace it, its about a $20 part that's held on the exterior of the case by one bolt.
Should be easier than changing your oil.
Ok thanks I'll get on that as soon as possible the weather here is bad right now when it clears up for a bit i'll try it. What if there is no vac on the line then what do I do.
ok weather cleared up for a bit I went out and checked the vac there was good vac on the line so I replaced the vac modulator and if shifts MUCH BETTER!!!!! thanks for the help guys.
ok guys the trans shifts good when u give it alittle gas but when you romp on it it shifts hard from 1st to 2nd but not so hard 2nd to 3rd. I was guessing it's because of the torq converter on the trans. Could that be why it shifts like it does. I don't mind the hard shift like that I was just wondering if that was it or if it was something that needed to be fixed.
The torque converter has nothing to do with the firmness of the shift. Count your blessings... The harder the shift, the less wear is occuring on the internal clutches of the tranny. I buy expensive shift kits to make my shifts firmer
![]() If you bought an aftermarket vacuum modulator, chances are its an adjustable unit, or calibrated for a bit firmer shifts. If its adjustable, you can change the firmness and shift threshold. It may be different because the tranny is showing some age or because the vacuum modulator is calibrated slightly differently than the original. Either way, drive it. Its shifting, its not slipping, and your part replacement showed a positive change. |
Are you sure the vacuum modulator determine the firmness of the shifts?
I thought it determines when the trans shift, not the firmness of the shift. Thanks. |
Has it always done this?
Maybe a previous owner put a shift kit in it.
Ontario Rodders |
It has done this since I bought the truck. Now that I put a new vac modulator on which by the way is bigger than the one that was on there but thats the one auto zone says goes on my truck anyways it has always done that but now that I put that new part on when I romp on it it shifts hard into 2nd and sometimes churps the tires. i like it i just didn't want the trans to break because of something, so if it's ok then thats great.
Probably has a shift kit.....like was said, better to shift hard and fast than slow and sloppy.
Ontario Rodders |
The torque converter DOES affect shift quality.
If you are in freezing weather, the modulator could have condensation build up and be frozen. Does the problem get better when the vehicle warms up? |
| 98 blazer shifts hard | michiganda | Transmission - Rearend | 5 | 07-06-2005 05:27 PM |
| TH400 power handling and RPM range | Philly Single | Transmission - Rearend | 3 | 09-28-2003 04:51 PM |
| 700 R4 shifting hard | jpd37 | Transmission - Rearend | 8 | 09-22-2003 03:49 PM |
| shifts hard | mikeh | Transmission - Rearend | 3 | 12-04-2002 07:26 PM |
| TH400 in firebird v/s TH400 in bonniville help | speedfrk3 | Transmission - Rearend | 11 | 11-04-2002 11:19 AM |
