th400 slipping 3rd gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2008, 06:07 AM
Got a th400 tranny was rebuilt year and a half ago
worked fine for first 400 miles
1-2 shift is firm all good 2-3 shift is soft but after 30-45 seconds in 3rd
it starts slipping.
I can pedal it and get it to grab 3rd for a second or two then starts slipping again.
reverse gear and clutch is fine (this is the same clutch thar 3rd uses correct)
so I don't think it is the clutch
has to be a broken spring or stuck pistion for the 2-3 shift circuit?
can any one give me a diagram on where this is in the valve body
have put shift kits in trannys before but that all
willing to give this valve body fix a try if I know where to look
Old 04-26-2008, 10:05 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
it starts slipping.
IF you have troubles in 3rd gear , the frictions are burning.
Reverse gear does use the same clutch BUT the pressure in R is boosted . That will cover up a weak clutch pack for a while.
I would suggest a tear down to find and repair the problem... any thing else is a band aide repair IMHO.
IF you wish , A TransGo 400-2 shift kit has a triple plate separator plate.. this will dual feed the direct clutch without disassembly of the transmission.
good luck , post back when you can .
Old 04-27-2008, 10:08 AM
The tranny was rebuilt clutches were new
it has just sat around while I finished the rebuild of the car
I was thinking it was 2-3 spring broke or stuck piston in that circuit that was not letting pressure build up very much
sound reasonable??
Old 04-27-2008, 01:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
sound reasonable??
nope....... slippage is slippage. Frictions are thin and burn quickly.
I'd find the problem soon before you pay for a rebuild again
89 2500 with a t-400 , no 2nd 3rd gear calhoun Transmission - Rearend 3 02-04-2008 08:40 PM
no 2nd or 3rd gear sik400 Transmission - Rearend 7 07-17-2007 10:14 AM
th350 slipping out of third gear... flipp121 Transmission - Rearend 4 12-10-2006 02:39 PM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 05:31 PM
no 3rd gear , Help chevtruck Transmission - Rearend 3 09-29-2004 07:09 AM
