TH400 Stock Stall - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 10:14 AM
TH400 Stock Stall
Does anyone know what the stock stall convertor is rated at in a th 400?
Old 04-04-2006, 11:27 AM
transmandan's Avatar
Automatic Trans Specialist
stall speed
A stock THM 400 converter is about 1500-1600 around that
Old 04-04-2006, 08:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the converters behind the high performance engines used a higher stall near 1800-2000 RPM.
Old 04-05-2006, 07:08 AM
Converter
Yes I would use a 2000 stall on the street I can get these if you need one
Old 04-06-2006, 02:12 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
. . . AND, so can everyone else who has the money to go to the local speed shop, or parts counter, or online speed shops.
This looks an awful lot like a solicitation for a possible monetary gain on your part, not exactly advertising, but not simply giving good advice either.
This is a borderline NO-NO on Hotrodders.com.
Old 04-06-2006, 02:38 PM
SO SORRY didnot mean to offend you It does take money to play, I was just trying to make it hurt alittle less
Old 04-06-2006, 08:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
There is no offense taken, it is a violation of the forum rules setup by Jon (admin guy).
If you wish to offer parts or services to fellow members please use the PM system on this board.
Old 04-07-2006, 07:07 AM
No problem crosley just here to help have a good day
Old 04-07-2006, 07:18 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Since it was NOT an outright advertisement or subject meant more for the Classifieds forum here on the board, I left it here, BUT it IS borderline and I was asked to give a real close look at it, maybe edit it, and possibly send a PM. I seen little need to change or PM, when a comment would suffice.
NOW, if you would have contacted another member via PM and worked out a price and sold something there, we have absolutely NO rules against this.
Old 04-07-2006, 07:31 AM
No problem M&M I will not do that again
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 04:36 PM
Th350 & Th400 Torque converters Houman SS '70 Transmission - Rearend 5 06-14-2005 06:18 AM
first post - IFS or rebuild stock? rhurley Suspension - Brakes - Steering 9 05-26-2004 08:30 PM
Stock C6 stall speed? Steve-0321 Transmission - Rearend 0 01-30-2004 12:20 PM
TH400 in firebird v/s TH400 in bonniville help speedfrk3 Transmission - Rearend 11 11-04-2002 12:19 PM
