th400 teardown
ok here is what i have done, and i have a problem. i am not a trans builder so i am not really familiar with all the technical names for all the parts, but i have built a functional trans. ok i pulled the pump, pulled out the first drum, the second drum,the band, a clutchpack. now i have a problem, i guess i am at a piston, i removed the snaprings, but the piston wont come out, there appears to be one more clutchpack behind it. is there something im missing. maybe a clip on the bottom of the case near the valve body. there seems to be no way to get the piston out, i even held the trans by the tail shaft and bumped it on the ground a few times, nothing. what am i overlooking? i doubt it is stuck, everything in this tranny came apart eaisly so far, i was even able to pull the pump by hand.
