Th400 will not shift into park, Help!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2003, 12:54 AM
Red face Th400 will not shift into park, Help!!
I have a 64 malibu ss, it has a 350 SBC and a TH400 turbo tranny. I have a B&M shifter that will not go into park. The reverse and drive work but it will not park. If the car is turned off and in drive or reverse the car can still be pushed as if it was in neutral. Any suggestions? Thanks
Old 02-05-2003, 05:39 AM
Tazz
Cool
Improper cable adjustment. Back everything off. go under the car and put it in park. Put the shifter in park. Adjust the cable, everything should be fine.
Todd
