Th400 wont shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2007, 05:36 PM
Th400 wont shift
i have recently put in a th400 in my supercharged 92 gmc in place of the stock 700r and i have hooked up the forced downshift wire, and the vacume modulator to the intake manifold. i put a check valve in line to the modulator so when i made boost it wouldnt effect the trans. it wouldnt shift out of first unless i placed the shifter into neutral then back into drive several times. i thought there wasnt enough vacume to shift it so i ran a vacume "t" to both the carburator ports and the intake, but still it wont shift it has plenty of vaccume to the transmition. what could this be??
Old 11-22-2007, 05:59 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Install a vacuum gauge at the line near the modulator to see the reading. 12 inches of vacuum at minimum should be there. 15 inches at idle would be better.
Was this t-400 known 'good' before the install? Fresh rebuild. Dyno tested after the build?
Does the wire you hooked to the trans case connector have 12 volts full time... it should not.
Old 11-24-2007, 12:47 PM
The circuit from your carb thru however you are controlling the juice ( micro switch) or other off of your throttle linkage, should be from a switched power supply. Mine is wired thru the ignition switch.
It should only be flowing current to the tranny solenoid connector at close to wide open throttle.
Quick check, if the solenoid in the tranny is working is to enregize and listen for a click from the tranny.
Do you have a one or two wire connector at the tranny?
Old 11-24-2007, 10:32 PM
i figured out the problem and it was much simpler than i expected.... it was just a bad modulator so i switched it with a new one and now it works great.
thanks alot for all your inputs. they were a lot of help.
? about a shift kit in a TH350 or TH400 Streetmaster Transmission - Rearend 1 04-26-2006 08:35 PM
TH400 rebuilt delayed shift into "d" oklowride Transmission - Rearend 7 12-14-2004 09:39 PM
th400 early shift/ soft shift 69er Transmission - Rearend 3 11-15-2004 07:16 AM
th400 2-3 shift?? camaroman7d Transmission - Rearend 6 04-22-2004 01:06 AM
th400 slow 2-3 shift amxerhull Transmission - Rearend 4 11-13-2003 03:19 PM
