TH400 Wont Shift Out of Park - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2005, 05:59 PM
Coming out of work today in the chevelle was an interesting experience.
I started er up and everything was fine.
Put it into reverse and back out, then drive. I idle arround the building, ok everything is normal.
Its extremely hot in the car so i decide to roll the passenger side window down to get some cross ventilation.
I decieded it would be a bit safer it i pulled over to do it instead of trying to lean over in the middle of traffic.
So i pull into a parking space and put it into park, roll the pass. window down but when i go to take it out of park, nothing happens.
This car has a B&M ratchet shifter which at this point feels very loose.
I get under the car and have a buddy hold down the brake pedal, i put it into reverse directly from that transmission and it starts rolling bakcwards, so whew i dont think the tranny is shot.
But i still have no idea what the heck is wrong, any ideas?
Edit/Delete Message
Old 06-03-2005, 06:31 PM
Crosley's Avatar
Wiki Edits: 1659
Sounds like shifter problems , not tranny problems
Edit/Delete Message
Old 06-04-2005, 11:39 AM
i took apart the shifter today and looked at where the cable hooks up.
Everything is all hooked up and secure.
I shifted it into park and looked at where the cable meets the trans.
Moved the shifter to the furthest setting and it didnt move the other end at all.
Im hoping it is just a simple cable break and it wont be that hard to replace.
So i went to both NAPA and Advanced auto parts and neither of them could even order the right cable.
Does it sound right?
Old 06-04-2005, 11:50 AM
Crosley's Avatar
Wiki Edits: 1659
check the shift arm at the tranny with the cable unhooked... should be detents that the shift arm of the tranny cliks into firmly as moved from park to low gear.
If it feels sloppy / goofy / loose , I'd pull the pan to check the nut on the shift arm inside.
If the cable does not move at the tranny end , then the cable is band / broke or the shifter is the trouble.
Unless your NAPA and advanced auto store sells B&M products I doubt they will have a cable to fit the shifter
TH400 rebuilt delayed shift into "d" oklowride Transmission - Rearend 7 12-14-2004 09:39 PM
th400 2-3 shift?? camaroman7d Transmission - Rearend 6 04-22-2004 01:06 AM
th400 slow 2-3 shift amxerhull Transmission - Rearend 4 11-13-2003 03:19 PM
Th400 will not shift into park, Help!! ltmanny5 Transmission - Rearend 1 02-05-2003 05:39 AM
TH400 shift point...help Ted655 Transmission - Rearend 1 10-14-2002 11:18 AM
