TH4l80e MT1 weird shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2010, 11:49 PM
I have a 96 c3500 SRW with a l-29-7.4L with the th4L80e ( series MT1) thats doing a goofy thing , when its cold out ( below 30 degrees which is warm for Canadians ) if i start and let it warm up alittle ( 2min or so ) or start of cold , it will go but the first stop I come to it will act like I am spinning the wheels then go into 1st gear ( like its slipping internally ) and it bangs into gear , it has 115K miles , fluid changed out at 60K miles with convertor flush ) level good when cold or hot . it only does this on days when its below freezing , and if I let it sit and warm up to 80 degrees on water temp it stops otherwise when warmer than freezing it shifts normal ( checked for water in fluid too ) . whats going on ??selinoid problem or ecm problem , No codes thrown when scanned at dealer .
Old 02-24-2010, 01:52 AM
sqzbox's Avatar
My pipes are my music
I had a problem with the exact same symptoms except it was a 96 dodge dynasty. I changed the fluid and filter and added a can of lucas trans tune. The problem went away immediately.
I was amazed because it was the first time a tranny additive had ever worked for me. That was my first and last attempt for an easy fix before either a new trans. or junk yard jewel to replace it. Drove the car another 50K before I sold it at 158K mi. still running good!
Old 02-24-2010, 06:22 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Internal seals getting hard
Old 02-24-2010, 09:31 AM
Note that the 4L80E has a pulse width modulated valve that controls internal hydraulic pressure. It also has input and output shaft speed sensors. If the computer senses slippage between the input and output shafts, it increases the line pressure up to the max allowable. This is why after the slippage, you feel a very hard shift.
Old 02-25-2010, 01:25 AM
So Joe ,basically I have a low line pressure, Like Pump going south??? or could it be the valve acting up ?? I want to try to make this thing last a while as I don't have $2500 handy to get a complete R&R'd unit and convertor ( built to towing specs )
Old 02-25-2010, 06:15 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The PWM ( pulse width modulated) system in the 4L80E is used only on converter clutch apply. It is not part of the main line pressure control. Two different items.
The bang into gear is simply the fluid and seals making contact when the trans is cold, the internals of the trans are spinning and it bangs into gear. That most likely is all that is happening.
Internal seals are getting hard and the cold temps you mention here are the cause..
To add one other thought here in the cold temps; check the fluid level and when was the last fluid service on the trans? Trans Filter changed?
Old 02-25-2010, 07:36 AM
SSedan64's Avatar
1st Post says (Fluid changed, converter flushed @60K) 115K now so it's due for another service. They may not have changed the Filter the 1st service & only flushed the Trans.
Old 02-25-2010, 07:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that is why I asked... 60k miles is too long for fluid service.
depend on vehicle and fluid type, 30k to 40k miles is my preference
Old 02-25-2010, 07:53 PM
filter was changed out when service was done , its dextron III , I should get a whole sevice and band adjustment done , trans service was done 5 years ago . fluid still red and not burn't , I'm going to lengthen warm up times for now .
Old 02-25-2010, 08:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no band adjustments in the 4l80e trans as a maintenance item , clearance is set when the trans is built
Old 02-26-2010, 07:38 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I'd try a can of Lucas Trans Fix, it can't hurt. I've had numerous transmission problems that chemicals have cured, or made better, at least for a while,
4L60e 2-3 shift slow after installing kit ckucia Transmission - Rearend 3 09-01-2009 12:09 PM
700r4 shift / tv question mican99 Transmission - Rearend 3 05-04-2009 10:08 PM
700r4 down shift question Jake_Dragon Transmission - Rearend 18 01-10-2009 04:29 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 11:21 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
