TH700R4 - 3 AND 4 GONE.how long till the 1st and 2nd ? i need to ride today - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2008, 12:03 PM
Hi i need to ride today
but im not sure how will it last and if i will be able to get there
my 3rd and 4th are toasted,how long till the 1st and 2nd fail ?
what you think ?
Old 08-16-2008, 01:03 PM
Crosley's Avatar
Wiki Edits: 1659
what you think ?
How long the trans operates would be an unknown item.
3-4 clutch pack failure in this trans is common.
The remainder of the trans may operate from 1 mile to 1000 miles.
Old 08-16-2008, 01:11 PM
so it can fail anytime
Old 08-16-2008, 01:51 PM
Last journal entry: How sweet it is!
yup!
trannys are a funny animal. I once had a 1991 Ford Tempo. It was used as a winter beater up here in O'Canada. The tranny in that thing had been "SLIPPING" for about 3 years. then one cold morning that was it! went to pull away and had nothing! Probably an absolute miracle that it lasted that long after the slipping had started
