TH700r4 input shaft. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2010, 11:41 AM
Hello, i have a 1991 2WD 1500 chevy pickup and the tranny went out of it. i found a tranny out of a '92 S-10 and did some research. the one from the '92 has a 27 spline input shaft and the one for my truck has 30. i was wondering how much trouble it would take to change the shafts around.
Old 06-12-2010, 11:31 PM
Wiki Edits: 85
Not much. Pull pump and swap aluminum drums. You may need to swap parts in the drum if your old parts are bad. It is not advisable to press shaft out of drum and press other one in.
9 inch & Drive Shaft Swap Morgan22 Transmission - Rearend 2 06-21-2008 02:30 PM
Yet another problem, oil pump shaft..... sexypizzaman Engine 8 06-13-2008 05:19 PM
Leaking Selector Shaft seal TH350 longt Transmission - Rearend 5 01-21-2008 06:09 AM
Input shaft check ball 8843astro Transmission - Rearend 3 03-19-2007 03:29 PM
M21 input shaft looseness mrl Transmission - Rearend 3 01-16-2007 01:28 PM
