TH700R4 Reverse drum problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2008, 12:10 PM
Hi i purchased a brand new reverse drum for my TH700R4
and i find out that the piston that is supposed to go inside
does not fit the same way,its floating !!!!
The clearance circled in red is thicker...what's the problem ?
and it seems like extra space,this is the NO CHECK BALL version,the original has a check ball
thanks
http://www.bulkpart.com/Merchant2/me...roduct_Count=1
ps : on the original drum it does fit very well
OLD DRUM WITH PISTON
NEW DRUM WITH PISTON
Old 09-14-2008, 12:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the reverse input drum with the steel piston is an first design.
the drum you have purchased is the 2nd design , this uses an aluminum piston.
Old 09-14-2008, 12:46 PM
so i won't be able to use it till i get the right piston ?
Old 09-14-2008, 01:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that would be correct.
You need thinner frictions , the bevelled style cushion too.
Springs and retainer are the same
Old 09-14-2008, 01:18 PM
i will have to use the old drum,its pretty good
TH-350 reverse problem. Eric327 Transmission - Rearend 5 03-28-2006 06:08 PM
Engine stalling problem JamesRS Engine 3 01-30-2006 11:22 AM
Making a reverse shape in sheet metal John Kelly Body - Exterior 4 12-16-2005 08:24 PM
Stuck brake drum on '53 Packard Malibucdl Suspension - Brakes - Steering 7 09-16-2003 08:51 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
