TH700R4 Trans Mount Abuse - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2012, 08:13 AM
malc's Avatar
Living At The Speed Of Life
Over the last two years Iīve had to raise the motor in my Camaro,
new timing chain and cover, new headers on, later off to paint,
oil pump twice.
Everytime I unbolted the front engine mounts and jacked the motor up I never gave the rear mount under the trans a thought.
Hereīs what I found after hearing clunking noises in the corners.
Old 11-23-2012, 11:39 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Ooo I see.
If the Camaro is a 3rd or 4th generation, the trans mount takes the brunt of the load from the 'torque arm' too. Double Whammy!
Old 11-23-2012, 11:48 AM
malc's Avatar
Itīs a 3rd gen.
I should have inspected it everytime I was under the car.
Old 11-29-2012, 08:18 AM
Hello Malc, Good to see a fellow 3rd gen owner. One way to remove some of the stress from the rear trans mount is to switch to a torque arm and cross member assembly from someone like Spohn or UMI. They move the front torque arm connection point from the rear of the trans to the crossmember itself. I guess it's a big improvement in launch as well. Plan on doing this myself once I get my new trans built.
Chevy Trans Mount Dimensions Old Rotor Flap Transmission - Rearend 1 02-06-2010 07:03 PM
TH350 Trans mount Eric64 Transmission - Rearend 3 01-23-2008 08:31 PM
Futura Trans Mount 1983lux Transmission - Rearend 0 10-03-2007 01:40 PM
Solid Trans Mount? KA67_72 Transmission - Rearend 6 04-27-2003 07:34 PM
63 fairlane c-4 trans mount FAIRLANE DUDE Transmission - Rearend 0 04-01-2003 01:09 PM
