Thank You To Everyone For Their Help On This - It's Strong - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 04-03-2013, 12:18 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Just wanted to say thank you for everyone that gave their input into this build. It sounds and runs strong.
Old 04-03-2013, 12:29 AM
vinniekq2's Avatar
great vid,reminds me of when I pitted for a midget using a 2 liter alcohol Datsun engine.we raced at Arlington.in and out direct drive gear box and a seat
The Following User Says Thank You to vinniekq2 For This Useful Post:
S10 Racer (04-03-2013)
Old 04-03-2013, 06:33 AM
Congrats on the build-it does look and sound good!
From a fellow 410 sprint racer, can I give you some advice that you've probably already heard?
First, with a injected motor on alcohol, don't let it sit there and idle cold with the fuel valve on. You are just washing the cylinders with fuel and it will never warm up. You need to close the shut off valve till rpms start climbing and let it run lean for a few minutes and warm up any time you are just idling the engine. Noticed your temp gauge hadn't moved yet-even with some playing around in the yard. Being put under a load when cold is one of the hardest things on sprint car engines. Getting it up to temp before shutting off will also help to evaporate the excess fuel out of the oil.
Second, please stop being stupid and starting the car without even having your seatbelts on. I do start mine without my helmet sometimes, but I don't normally go horsing around either. Without the belts is a big no-no! Take it from someone who has had a throttle stick when starting the car and making a run down a deserted road. It scares the crap out of you! By the time you correct from almost going in a ditch from instinctively hitting the brakes (with no RF brake) and think to turn off the switch, you travel a long ways!
Best of luck with your racing!
Dana 44 - How strong are they? 31fordcoupe Transmission - Rearend 4 06-29-2009 01:40 AM
How strong is the Fordomatic? prodigal son Transmission - Rearend 4 06-09-2009 08:53 PM
Strong Enough?? chevymastermind Transmission - Rearend 11 02-28-2006 09:21 PM
ONly for the strong 5.0 freak Hotrodders' Lounge 3 10-09-2004 12:34 AM
??? STRONG ENOUGH??? ss crazy Transmission - Rearend 5 12-13-2002 01:22 PM
