Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Thank you Street Rodder Magazine
  #24 (permalink)
Old 12-31-2012, 06:04 PM
deckofficer's Avatar
deckofficer deckofficer is offline
Last wiki edit: List of hotrodding forums
Last journal entry: Trans swap
Wiki Edits: 12
Originally Posted by NEW INTERIORS View Post
You can have all the HP you want... If you can't put it to the ground,, it's just for look's..How fast are you trying to make this car ??? When is fast enough ???
Fuel mileage could be close to my torque motor with the EFI instead of a carb. The plan is to have a ride with good street manners including a good idle, mid 20's for mpg on the highway, over 1.02 G cornering, and still rip a mid 9 second ET. Since the EFI 427 has 140 hp more than the 355 that turned a 10.8, and the car weighs 1790 lbs where an additional 140 hp will make a big difference, I believe I'm on track (no pun intended) for my idea of the "Swiss Army Knife" of hot rods.
That is all I want, 25 mpg, 1.02G cornering, good street manners, and mid 9's. Then I will finally be done.
