Is there any probs with my ign? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2002, 01:02 PM
5.0Towncar's Avatar
Post Is there any probs with my ign?
2 years ago I put NGK's in my car.They were the cheap 1 dollar and some odd cents. Anyways, when I was permenently removing my A/C compressor,smog pump, and belt,I decided to check the plugs on that side to see if they were ok because prior I was getting rough idle and backfires, and I saw that on the front plug it was busted into pieces and the core was broke. What could have been the problem? Well since then I put Motorcraft double platnum in it and it's fine, are those any good plugs? I hope so for $3.60 a piece.
Old 11-01-2002, 01:23 PM
Tazz
Cool
That plug was probably cracked prior to or during instillation. While running the engine the plug disintigrated itself/fell apart. I like these platnum plugs but ran the NGK's in my drag bikes for yearrrrssss! The NGK's were never a problem for me. I think you got a bad plug.
Old 11-01-2002, 01:26 PM
5.0Towncar's Avatar
Post
So Motorcrafts suck? <img src="confused.gif" border="0">
Old 11-01-2002, 01:28 PM
5.0Towncar's Avatar
Post
Well I'll say this. I have Accel wires and cap & rotor, and a Borg Warner coil. I advanced my timing just a bit because it was pinging when I replaced everything.
Old 11-01-2002, 01:36 PM
mustang66maniac's Avatar
Ford Freak
Post
if you advance your timing more while it is already pinging, it will make it ping more.
Old 11-01-2002, 02:24 PM
5.0Towncar's Avatar
Post
well I think I advanced it, I forgot,it was like 2 years ago. I think I turned it counter-clockwise. Correct me if I'm wrong <img src="confused.gif" border="0">
Old 11-01-2002, 03:02 PM
Post
a plug is a plug. they are only as good as the rest of the ignition. plugs will not make magical power. how ever some plugs do fire better in certain conditions.
but going to platinums will not yield more power they will just not wear as fast.
they rest of your ignition set up is fine. but if your still running the computer. you need to disconnect the timing plug and check you timing before messing with it. then reinstall it.
on a stock 5.0 they seem to like 13 to 15 degrees advance best. dont mess with the fuel pressure more is not better.
if you ping then try higher octane fuel like 89 or 92.
Old 11-01-2002, 03:38 PM
dmorris1200's Avatar
doesn't play well with others
Post
Hey towncar, do you just make this stuff up as you go along or what? I got one for ya. Two years ago I was driving down the interstate and my camaro farted, do camaros suck or what ?
BUILT FORD TOUGH
Old 11-01-2002, 07:29 PM
5.0Towncar's Avatar
Post
to tell the truth dmorris I could give a ****
