Is there a "Best" Vacuum Source for PCV? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2010, 05:48 PM
acr acr is offline
Which of the common PCV air pick up methods do you think is more efficent &/or prefer? A breather in the valve cover, or a fitting & hose from the bottom of the air cleaner to the valve cover?
Old 05-28-2010, 05:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I place the pcv valve in the passenger side valve cover and run the hose to the base of the carb. Works best for me , and it's usually how it is done from the factory also or use to be anyway.JMO
Cole
Old 05-28-2010, 06:39 PM
acr acr is offline
Cole, correct. But I'm asking about the other side valve cover where the fresh air is picked up & circulated thru the crankcase, back up to the PCV. The two most common systems (there are others) use either a push, twist, or clamp in breather that fits in the valve cover & picks up air arond it. The other style has a fitting that screws/clamps into the air cleaner where it pick's up fresh air & sends it into the valve cover thru a hose.
Old 05-28-2010, 07:47 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
IMHO the clean air from the air cleaner into the system is best. The push on breather in most cases will also suffice, but combined with a style that has a hose connection as well as some expanded metal inside the breather to the in-side section of the air cleaner will give the best filtration.
Old 05-28-2010, 07:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The air cleaner would be nice, clean air, for sure. I think the extra work to plumb an aftermarket filter base is off-putting for some guys. That, and that the filter assembly can't just be whipped off by removing the wing nut is probably why most end up using a v-cover mounted breather.
But I agree the v-cover breather will work as well, as long as the breather has good filtration.
Old 05-28-2010, 11:36 PM
sqzbox's Avatar
My pipes are my music
Good idea only with a large like 14" air cleaner. If you use one of those little bitty air cleaners, the breather hose to the cap will be competing with the PCV valve because of the vacuum created by the carb. trying to suck air through a too small air filter.
If you look at an older stock GM air cleaner, the breather hose was hooked up to the air filter housing on the side with a small foam filter inside before the air filter. This small foam filter had to be changed periodically as it would get coated with oil from the breather cap. I never did like that and always changed the breather cap to a style without the hose.
F150 issues ALL FORD Transmission - Rearend 27 06-30-2009 04:28 PM
Need Correct Procedure in Timing SB newdad1 Engine 92 08-02-2007 05:31 AM
Vacuum advance not active at cruise (port vac source) - help hotrodf1 Engine 21 06-25-2007 03:50 PM
at wits end on ford brakes....... crazy larry Suspension - Brakes - Steering 30 04-06-2004 05:39 AM
early optispark vacuum source 48Man Engine 7 01-16-2003 01:17 PM
