Is there different TH700R4? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2010, 12:15 AM
I have been looking for a 700r4 and i have run into a problem. Is there different ones? Some i have seen for sale have been behind s-10 pickups with V-6 engines. Some are advertised with a small bell housing. I am needing one to go behind a 406 sbc. any advise?
Old 01-31-2010, 07:23 AM
Wiki Edits: 85
700s have several different bells.
1) S10 type for small V6s and 4 cylinders
2) Chevy type for larger V6s and V8s with plastic/tin dust cover
3) Chevy type for larger V6s and V8s with aluminum dust cover
Old 01-31-2010, 09:12 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
The difference is the 60 or 90 bell housing bolt pattern, the 90 V6 trannies are a little different than V8 trannies inside, (less clutches), but that can be changed during the rebuild process if desired.
Old 01-31-2010, 09:54 AM
SSedan64's Avatar
Yes, as described in above posts^^^.
60*deg = 2.8,3.1,3.4,3.8 V6
90*deg = 4.3 V6 same as SBC/BBC.
Old 01-31-2010, 10:09 AM
Last journal entry: headers
also try to find one that is 87-93 they are a bit stronger. they have a K on the bell housing.i believe on the passenger side.
Old 01-31-2010, 10:20 AM
Rickracer's Avatar
87 to 03 is actually a 4L60, prior versions were the 700R4. They are commonly all lumped together as 700R4s though. Earlier versions had a 27 spline input and a 7 vane pump, 4L60s had a 30 spline input and a 10 vane pump.
Old 01-31-2010, 10:41 AM
to keep things simple 4l60-700r4 87-93= same tranny just better than the earlier trannys
Old 01-31-2010, 01:11 PM
And to think all most every one said hotrodders used 350's cause they were cheap and every thing was interchangeable not like the 302 FORD I am using .three different bell housings oh don't all you chevy boys jump on me now cause i'm just pulling your chain a little yea the last three rods I built had 350's one with a 350 tranny the orthers 700r4 . The bell housings were on the things when I got them so I did learn some thing today.
OLDROD
TH700R4 Reverse drum problem Calderone Transmission - Rearend 4 09-14-2008 02:18 PM
TH700R4 Tv cable? TheStripe Transmission - Rearend 5 04-04-2005 04:36 PM
TH700R4 info Frisco Transmission - Rearend 1 03-12-2005 07:13 PM
th700r4 JMac19 Transmission - Rearend 1 09-30-2003 08:55 PM
Are all TH700R4 trannys the same chevylovingfarmboy Transmission - Rearend 5 03-08-2003 07:57 PM
