Is there a foolproof way of adjusting the THROTTLE VALVE? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2005, 03:47 PM
Frmly sc*ot.
Is there a foolproof and universal way of adjusting the THROTTLE VALVE?
Thanks.
I have an 87 Olds with a self adjusting cable, but what if it didn't have it or it didn't work properly?
Old 11-09-2005, 04:53 PM
Ricky Rocket's Avatar
Drive it like a rental!
Throttle valve cable
The idea of the TV cable is the cable should be at the end of its travel at the same time the throttle is at wide open throttle. One of the problems with non factory set ups is the geometry for the cable bracket and accelerator linkage is not the same as factory.
If you cable is adjusted too long your shift points will be too early and if it is too short the shift points will be later.
Rick
Valve Rotator's and lifter rotation Old School Nut Engine 5 05-11-2005 10:07 PM
Bad Air Valve black66 Electrical 8 04-12-2005 12:44 PM
Broken valve spring??? Miligav383 Engine 6 05-16-2004 09:40 PM
Valve Adjusting? fsiramps Engine 8 02-18-2003 09:56 PM
PONTIAC ROLLER ROCKER/CAM 455 VALVE ADJUSTING trannsientorca Engine 2 11-10-2002 09:13 AM
