Is there a manual oil sending unit that doesn't leak.....? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2010, 07:02 AM
I've got a manual oil pressure gauge on my sbc 327. Gauge works good well, but I can't seem to find a decent sending unit that will not leak... Is there a unit to try that I am missing somewhere...? Any tips to keep them from leaking...? I am using the brass nipple that screws into the block and then another nipple that screws the plastic line into the bottom nipple. My leak is not at the line, but the brass fitting...? I have checked and it is tight. Any ideas...?
Old 06-04-2010, 07:23 AM
Manual oil pressure gauges typically don't have a sending unit.Try the copper line instead of plastic.You can buy the line seperately in most places.There should be a compression fitting in the too.Are you getting the compession fitting in the fitting where it needs to be?
Old 06-04-2010, 07:28 AM
Yeah, the compression ring is there. Just seems to be leaking from brass fittings...
Old 06-04-2010, 07:58 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
If you over tighten the line to the fitting they will leak, start with snug.
I have used braided line and fitting in the past, never leaks.
Old 06-04-2010, 08:10 AM
OLNOLAN's Avatar
Get the correct fitting
Hey Robbie, When using tubing connectors with plastic tubing you need to get the fittings with the insert that goes inside the tubing to keep the ferrel from cutting/crushing into the tubing. Also, tighten it finger tight, then 1/4 turn more with a wrench. Check for leaks, you may have to snug just a tad but never more than a 1/2 turn past finger tight. Better quality fittings give better results than the junky stuff too. olnolan
Old 06-04-2010, 09:37 AM
Thanks, appreicate the advice. Well, maybe I have it too tight... I will buy a new fitting pack and try again. Probably need to move towards some better quality fittings as well.... Would using some teflon tape help at all to seal the fittings together...?
Old 06-04-2010, 09:43 AM
OLNOLAN's Avatar
teflon tape
Hey Robbie, The only place you need teflon tape is on the male pipe threads, none on the tubing end of the fitting. olnolan
oil pressure sending unit jamesoldlym15 Engine 1 04-19-2009 05:04 PM
Can't islate oil leak 350 Chevy longt Engine 5 02-11-2007 10:58 AM
Extreme Cold vs. Oil Sending Unit. DeathRattle Engine 5 02-10-2007 05:49 PM
oil leak rb8179 Engine 11 06-03-2006 03:07 AM
Oil Sending Unit Assistance MI2600 Engine 3 09-11-2002 07:55 AM
