Is there a percentage of the free length height a spring should be compressed to ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2011, 02:57 PM
iceman36's Avatar
Hi
Have a Coil spring question.
I am finishing up custom IFS I building.
Have no idea what the final weight is going to be yet.
Would like to fabricate upper and lower mounting points for springs temporary
for clearance fitment.
Questions:
to at ride height?
Or just 1", 2", ....etc. greater than the maximum rebound length when installed?
I know about Spring rats, angel, position and wire size Etc. in relation to vehicle weight.
But I think I heard some where a spring should be compressed to a certain
percentage of its free length at ride height if possible?
It has to be some design of conventional Coil Spring not coil over!
There is no other vehicles I can directly reference it to.
ICE
Old 05-20-2011, 10:29 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
The way I see it is...
A. The spring should be long enough so that when the suspension goes into full droop the spring still has some load on it. (like you stated)
B. The spring should not be so long so as to bind when at full bump.
C. A softer spring with more preload is better than a stiff spring with less preload.
D. There is no "sweet spot" for springs. Most springs are constant rate so they can be run anywhere as long as the above parameters are met.
E. If you are using a variable rate spring, you will likely not want the "soft" part of the spring to be stacked or bound when at normal ride height. But this depends on the rate of the stiffer part of the spring. There are many variables to determine in the use of progressive rate springs.
Andy
Old 05-22-2011, 02:31 PM
iceman36's Avatar
Thanks Andy
Its always nice to get a answer to what seem a simple problem.
That was nagging at me.
ICE
Height, weight, length for '57 Chevy pu cares Body - Exterior 8 07-28-2008 08:15 AM
Spring Height???? dhunt00c Engine 6 05-10-2008 07:18 PM
Compressed Valve Spring Fatigue Garbonzo Bojangles Engine 8 01-25-2006 06:44 PM
Spring height?? Bluepen Suspension - Brakes - Steering 2 05-30-2004 07:23 AM
Installed Spring Height DTL504 Engine 5 01-21-2004 07:57 PM
