-   -   Is there a Spray gun with a long wand, for rustproofing inside frames etc. (http://www.hotrodders.com/forum/there-spray-gun-long-wand-rustproofing-inside-frames-etc-118185.html)
Ripped 06-15-2007 08:48 AM
I want to spray zero rust (thinned to mfg specs) inside frame components. Does anyone had some suggestions, ideas or thoughts on this?
The alternative is temporarily making each area sealed, and then filling it with zero rust. This would take 2 - 3 gallons at least (for example inside the rocker panels)
richard stewart 3rd 06-15-2007 09:42 AM
Hi,
You can use a bug/garden sprayer.
Take care,
Rich
35WINDOW 06-15-2007 09:45 AM
Maybe somebody beat me, but how about this?
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
OneMoreTime 06-15-2007 11:15 AM
How about an airless gun with a long tip? we have those for hard to reach places. or perhaps a fellow could rig a long tip on one of the siphon feed guns we use for applying wash material..
Just an idea or two..
Sam
sevt_chevelle 06-15-2007 11:44 AM
3M and wurth make a gun that comes with a 4-5ft long flex wand that sprays in 180 and 360 degrees. You can get different cans of paint like rust fighter I, undercoating etc. Can get empty cans and put in your own paint like epoxy.
Sata at one time made a flex wand gun but dont know if they still make one, am sure its high dollar. The 3M gun can be had for around 60 bucks...Eric
Ripped 06-15-2007 12:29 PM
I tried a local tool supplier. I bought an undercoating gun with a short straight tube end. I am going to hit the home depot, and see if I can get some semi ridged plastic pipe, like for connecting sinks etc. I figure I can heat up a pin or similar with a torch and use it to burn small holes in the sides of the tubing. I I dead end the pipe, I am hoping it will spray to the sides.
