Is there still air in my system? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2014, 11:47 AM
Changed the rack and pinion cause it was leaking pretty bad.. Now that it is on notice a notchy feel to it when I turn. With front of the car up (and running) you can actually see the wheels kind of twitch as the wheel is being turned. I've bled the system twice thinking it is air,but nothing helped.
Im wondering since the old rack was leaking for a while if it got low enough to do some damage to the pump? The steering is a little stiffer then I remeber. Just to add I don't hear and strange sounds from the pump. I can hear a little bit of a noise coming from the rack,but Its very minimal.
Thanks for your help!!
Jason
Old 07-27-2014, 06:15 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Did you flush the system ? Also, bleeding the system can sometimes take a while. Raise the front-end and turn Lock to lock slowly AT LEAST 20 times. Watch the fluid in the pump for bubbles.
I went through this last summer. EVERY new piece except one hose turned out to be defective.
Good luck to you.
454 RATTLER
Old 07-27-2014, 06:29 AM
Good luck to you.
454 RATTLER
Thanks for your reply. Did I flush the system? No. Everything is new except for the pump. Am I missing something here? Ive been letting it sit and turn the wheels every now and then with the front up and engine off. I noticed I did have some real small bubbles in the resivor so Ill still crank on it a while see what happens. I'm glad to hear I'm not the only one with this problem
Is shop air safe for a fresh air breathing system? 777funk Garage - Tools 15 04-18-2012 10:40 PM
My New Air System Workingwoods Garage - Tools 8 05-23-2008 07:25 PM
air in cooling system markiemyster Engine 5 03-04-2006 03:34 PM
Show off your homeade/ancient air compressor/air supply system! ChevelleSS_LS6 Garage - Tools 2 08-07-2005 07:39 PM
stealth cool air intake system for 55 Bel Air Berliner Bel Air Engine 9 11-30-2004 03:32 PM
