Is there a trick to this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2008, 11:05 PM
I am restoring a 66 GTO. I am trying to remove the quarter window and the regulator. I am having trouble getting the window out. It appears that the front channel guide cannot be removed making it difficult to take the window out. Is there a resource I could consult on this?
Old 05-25-2008, 05:39 AM
it should be held in place with a couple of small bolts(3/8) i think at the bottom of the roller window track
Old 05-31-2008, 03:45 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
If it is anything like my '62 Impala it all comes out together. the long track and quarter glass. I know I had a bear of a time getting mine out but then I found the sweet spot that would le the glass go out and the channel in slightly. If I remember it has to tip forward, them towards the outside a hair, up then out a little more.
trick flow aluminum heads Id # Danscam Engine 3 06-05-2009 11:41 AM
Jethro's Cool, Radiator Trick Sean's Engine 8 02-06-2007 05:09 PM
what holley trick kit do i need for a 3310-3 carb? tiresmoke55 Engine 11 12-06-2006 10:16 AM
Trick Flow top end RCastle Engine 4 01-08-2005 08:19 PM
Edelbrock Vs. Trick flow vs Brodix Lthompson Engine 2 10-10-2004 09:20 PM
