is there a visual way to tell cast from forged crank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2005, 07:09 PM
I've got a Mopar 440 NOS crank and was asked if it was cast or forged.
Name:	mopar crank casting marks.jpg
ID:	7895   Click image for larger version
Name:	Mopar crank tag.jpg
Old 11-17-2005, 07:26 PM
347mustang's Avatar
not sure about a mopar crank but on chevys the casting line that runs down the middle of the cranks is real thin for a cast and thick for a steel crank
Old 11-17-2005, 07:52 PM
I thought Chevy cast cranks had the thin seam and forged were the wide seam? And the froged have a nice even surface (smooth ) on the counterweights while the cast are grainey.
Old 11-17-2005, 07:55 PM
willys36@aol.com's Avatar
Wiki Edits: 21
That is a cast crank. See the really thin sharp parting line on the rough cast part of the counter weights? That is the casting partign line. If it were a forged unit, the 'parting line' would be quite wide and smooth. Of course, all early Chrysler hemis have forged steel cranks, unlike the majority of Chevys and Fords with their weenie cast iron ones.
Cast crankshaft example. See the sharp partign line?
Forged crankshaft example. See the wide parting line?
Old 11-17-2005, 08:03 PM
347mustang's Avatar
i fixed it, i missed spelled thick and thin..im retared some times
Is it a Steel or a Cast Crank? ProStreetNova Engine 32 03-11-2011 05:43 PM
Forged Crank Advantages, do I really need to use it? Houman SS '70 Engine 4 05-03-2005 03:27 PM
Cast steel or Forged Crank????? brainsboy Engine 14 02-20-2004 08:53 AM
Scat forged or cast???? 406chevelle Engine 13 06-20-2003 05:12 AM
Forged steel or cast crank? MopaRV Engine 1 12-20-2002 04:33 PM
