Check for continuity in the rotor button (sometimes will burn) and the contact that rides on the center electrode on the rotor button. Both are subject to failure on the HEI.
still wont start
new cap and rotor, new condensor, plus all of the above. i have continuity between coil and distrib. wires. no spark at all. am i missing something stupid. the rotor does in fact turn around and round when the motor cranks. is it possible that even though i have juice to the dist. that i don't have enough juice to fire up the motor? alt going bad? how do i test the alt with my multi meter?
Try a different module
Do you have a Haynes manual, if not put out the $15 bucks and get one.
Your original question would have been answered in the ignition chapter. I won't tell you how, but its SIMPLE. If you have checked everything then the answer would have been a running engine. Besides a new capacitor is not expensive. When did the problem first happen, going down the road, or after you started working on it? Most likely it's something you could check with a multimeter, and pulling the plugs won't answer the problem if its before the wires themselves. I could walk you through what to check but with communicating on this board that would take a whole day, and I'm not cheap. OR you could look through the Haynes, or Chiltons (I have both for every vehicle I have ever owned) and step by step test everything with a multimeter and have the problem narrowed down in an hour. Good luck |
yes i have a manual and a multimeter. and i did all the test in there and nothing. i did get a condensor. it was the pickup coil that was 45 bucks. but i tested the pickup and it tested ok. finaly got fed up and baught a used distrib from the junk yard. guess what....the damn thing runs now. so i don't know what the hell was going on and who knows, it could happen again.
at least it runs- for now..... must be them damn gremlins! thanks for all the help |
Oh well, look on the bright side. You got all new parts to put in that junkyard distributor. It ought to give years of faithful service.
