thermistate housing leaks like crazy help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2004, 12:28 AM
calimstng66's Avatar
i own a 1966 ford mustang with a 289 and my therm. housing leaks like no other. i changed the housing and it did fine, but started up again. If you are familiar with the area i am talking about right where the housing and the engine meet is where it leaks. please help
Old 07-21-2004, 12:48 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
is there a small crack in the tstat housing? you said it was replaced....
how about on the intake? what does that surface look like?
was the gasket surface absolutely clean on re-assembly?
is the hose good?
just thinking outloud.....
Old 07-21-2004, 02:54 PM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
is there a gasket on that t-stat housing? should there be? Try sealing it with some RTV.
tbw
Old 07-22-2004, 01:28 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Is the housing warped? Set it on a flat surface to check. Surface it with a wide file.
Old 07-22-2004, 08:43 AM
onebadmerc's Avatar
I need a bucket of arc sparks
I had a leaking thermostat housing on my car, it was one of those Ford Motorsports chrome housings. The housing was warped really bad so I went back to a stock housing and never had a problem since. Try running a big file over the housing or the mating surface on the intake, either surface could be a little bit off.
